I had some AVI movies that I converted to mpeg 2 using TMPGenc. I used DVD Lab Pro to compile my DVD. When it was done compiling, the video_ts folder was full of vob files, but had no ifo files. The video_ts folder plays perfectly on my computer with WinDVD, but when I burn it and try to play it on my DVD player, the movie goes for 3 seconds, freezes, goes for another 3 seconds, and freezes again. This goes on and on. Could this be because I'm missing the ifo and bup files (do I need them?)? Also, I'm using ac3 audio, if that matters. How can I get these IFO files? Can I use IFO edit? Will it let me keep my menus and chapters and subtitles that I created in DVD lab? Thanks in advance. Any help would be appreciated.
http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit can recreate your IFOs for you - but no menus. Chapters and subtitles will be fine.
If in doubt, Google it. -
Welp, I tried using DVD Lab again. The IFO's were there and everything looked fine. But when I played it on my DVD player, the same thing happened. I tried creating the dvd with TMPGEnc DVD Author, and I got an error message saying my combined bitrate was too high.
Current bitrate is video: 9800, audio: 224, combined: 10024
The combined video and audio can be no more than 9.848 Mbps (9848 kbps).
Gah. Could this be why my movie is freezing like that? My bitrate is too high? Should I re-encode it? Thanks for your help.
Missing ifo
By Kurgan71 in forum SubtitleReplies: 1Last Post: 16th Jun 2009, 01:24 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
how to generate missing ifo file from dvd
By deejay.2001 in forum Authoring (DVD)Replies: 14Last Post: 2nd Jun 2008, 10:53 -
missing ifo-files
By scio_fantasio in forum MacReplies: 5Last Post: 12th Dec 2007, 23:04 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
