I ordered the following motherboard earlier this week after learning mine had died. http://www.newegg.com/Product/Product.asp?Item=N82E16813131484 Turns out my processor also fried. I want to make sure I get a compatible processor, so is there anything I need to look for besides a 478 socket? Can anyone recommend a particular processor or deal?
Originally Posted by rbautch
Any Northwood core processor will do fine with that motherboard.
Make sure you have the right type of memory for the motherboard. -
Northwoods perform better in most aspects. The newer Prescotts run really hot and only make up for this by being faster in a very few things. If you can still find a Northwood I'd get that first. Maybe get a used one off eBay?
FB-DIMM are the real cause of global warming -
Thanks for the replies. I'm looking for 3.0 or 3.2. I'm still a little confused about the Northwood versus Prescott. Why would Intel come out with a new processor that runs hotter than the last version, which minimal speed increase? By the way, thanks much to budz and erdons for recommending that motherboard to me in the first place.
Because the Prescott is a 90nm process chip so the technology is better on paper. However the thermal issues inherent to the chip make it perform worse out of the box. If you go through the trouble of getting better cooling on the chip then you can get far better performance out of it, but then you can do the same with a Northwood and even overclock it a little to make up the difference. The pipes are shorter on the Prescotts so technically it should be faster, it just isn't in most cases though.
However Intel did fix this with the latest 90nm process cores, but you'd have to upgrade to an LGA motherboard for these, and then I'd be pushing the Pentium Ds like mad if you did.FB-DIMM are the real cause of global warming -
I think that 3.2 Northwood will treat you well, and that price isn't bad at all.
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Which Processor for my HTPC
By Bronx in forum Media Center PC / MediaCentersReplies: 4Last Post: 20th Oct 2010, 14:54 -
new processor
By alintatoc in forum ComputerReplies: 6Last Post: 21st Sep 2009, 03:16 -
Is it my processor?
By davej1983 in forum Software PlayingReplies: 7Last Post: 11th Jan 2009, 01:53 -
Processor
By Tom in HD in forum MacReplies: 1Last Post: 1st Dec 2007, 22:02
