I just created a VCD. When I play it on my DVD player, the video and audio are in sync. Everything is fine. However, when I fast-forward or rewind the movie and then hit play, the video and audio are no longer in sync!
But when I play either the mpeg file or VCD on the computer, then fast-forward or rewind, and then play, the audio and video never go out of sync.
Why is this? Does anyone know the problem? I de-multiplexed the mpeg file using TMPGEnc and it turns out that the audio file is four seconds longer than the video file. Is this the cause of the problem?
How do I fix it? Can anyone help?
Assuming of course your files meet the VCD spec, then the problem is your standalone player.
Double check your files meet VCD specs.Google is your Friend
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Can I save a Video/Audio being played on WMP/VLC/KMPlayer?
By ConverterCrazy in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2011, 01:27 -
Capturing a video with ffmpeg does not output audio when played
By oban in forum Capturing and VCRReplies: 0Last Post: 3rd Jun 2011, 11:11 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 20:31 -
Audio goes out of sync as video is played
By Ensign in forum AudioReplies: 6Last Post: 19th May 2008, 17:51
