    Jun 2005
    new york
    I've been struggling with this for the past week and couldn't find anything in past posts.
    1. I am adding anywhere from 4-10 assets to the program
    2. Run AutoLayout, then create Button text for each VTS
    3. Goto Menu screen and reposition menu text
    4. Select Quick DVD
    Using v2.0 (licensed) I can't seem to get the program to create a menu. It works fine with v1.5 but not 2.0 for me. Am I doing anything wrong.
    Also, is there a limit to the number of menu buttons (i.e. VTS's) I can have on the menu screen?
    Thanks for any help.
  2. Member lleader's Avatar
    Jan 2005
    Mississauga, Ontario, Canada
    I could be wrong about this (I have never used Quick DVD) but I believe QuickDVD doesn't allow a menu. Try just clicking on the icon instead of using it's pulldown menu (where you select QuickDVD).
  3. Originally Posted by lleader
    hes right dont select quick dvd just click on the icon to process your dvd
  4. Doesn't it say (NO MENU) right beside both 'Quick DVD' selections?
  5. Member lleader's Avatar
    Jan 2005
    Wasn't the (NO MENU) just added in the 'tester' version just released yesterday? Since Silverzman has been 'struggling with this for the past week' he probably doesn't have this version.
  6. Could be. Since I almost never use 'Quick DVD', I wasn't aware.
    A quick forum search would have solved his problem sooner (I counted at least six threads on this).
    My apologies silverzman.
    Jun 2005
    new york
    Ileader and BabyGonzo,
    Thanks a lot for taking the time to respond and helping me out. Sometimes it's the really simple things that tie you in knots.
    Thanks again to all.
    silverzman
