I just bought a NEC 3540 DVD-ROM/burner for my Pentium III. My computer recognizes the DVD, but is unable to play it in Windows Media Player stating that I should lower the resolution first. I'm currently on 1280x1024pixels. Is this absolutely necessary? I'd hate to change my resolution all the time I want to watch a DVD.
I went through the search feature and found some downloads for playing DVDs. I downloaded media player classic and while it successfully loads the DVD, the audio and video is messed up (green boxes everywhere and very choppy).
My question is whether there is something wrong with my DVD drive or is this software related? I was able to play the DVD on a standalone DVD player and it worked fine. I was also able to burn regular data files using my DVDROM without any problems.
Look in windows device manager (IDE controllers) and confirm that DMA is enabled.
You need to install a mpeg 2 codec for viewing dvds on your PC. windows media player and mpc use a third party codec, so install a dvd player as lumis has suggested, PowerDVD.
Im also running at 1280X1024 pixels and can play dvds fine without changing the resolution.
A pentium 3 with 512MB of memory is sufficient for playing dvds.
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
Problem Playing Copied DVD+R DL DVDs from CSS Protected Original
By bpbenda in forum DVD RippingReplies: 10Last Post: 24th Sep 2009, 09:04 -
By bpbenda in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2009, 13:42 -
Playing NTSC on PAL DVDRom?
By th3obr0 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Feb 2009, 23:18 -
Playing a h.264 aac MKV file with PowerDVD 7.3 nvidia purevideo installed
By maxpower2078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Jul 2008, 07:48
