Hi does anyone know if the philips dvp642/37player will play dvd-r dvds.As long as i had mine i have never had any one ever play.I know it plays everything but is this one form that it doesnt.Is there also a latest upgrade for this player.
Results 1 to 10 of 10
It plays dvd-r's fine. Perhaps you are not recording them properly. You should use ISO (data mode) and make sure your files don't contain QPEL.
The latest firmware update that I'm aware of is 630 v0112 -
Yes it does...I've used numerous different brands without any issues.
You won't need a firmware update to fix your issue. The only difference between the different versions of firmware deal with subtitles.Google is your Friend -
Hi there the dvds that i am burning are done on my sharp home dvd recorder.Its when i put them in the philips they spit them out.
I would imagine the Sharp records in standard mpeg2 format, but I'm not sure.
Have you tried a different brand of media?Google is your Friend -
I have tried different types od dvds and nothing plays.It is suppose to read dvd rws and it wont play those to
Have you tried using a different recorder to create a DVD on the same media your Philips is having issues with? Perhaps it is the recorder instead?
Nothing plays? Do your store-bought DVDs play? I've had my Panasonic DVP642 for quite some time, and it plays EVERYTHING I throw into it. What program are you using to burn your DVD-Rs? Are these ones you produced from your personal home movies?, or from backed-up copies of your original store-bought movie DVDs? What is the media brand and media code you are using?Originally Posted by pantangsThe more you know, the more there is to know...
Well it's most likely your recorder. Perhaps it is using QPEL or something like that.
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 14:06 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
Output resolution for Philips DVP642
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 00:41 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 12:43
