i downloaded a .srt file with winsubtitler, opened it with subtitle workshop then saved it as a .ssa file.
i start virtualdub> video> filters> add> subtitler (Avery Lee) browse for the .ssa file then go to preview and the subtitles do'nt appear.
if i save the .srt as .ssa with winsubtitler it works in virtual dub but its all to the right and i couldnt correct it.
where am i going wrong?
you can use the srt
https://www.videohelp.com/forum/viewtopic.php?t=272736 -
oops posted on guide one first by mistake.
have been at this all day, still can't get it to work.
i'm giving in till tomorrow.
thanks baldrick
together we will beat this lol -
found the proper subs.
started using another of your guides https://www.videohelp.com/forum/userguides/153058.php
using ffshow coz vobsub will not install.
went to use tmpgenc and it wouldnt load, "can not open or unsupported"
so thought i would try mainconcept instead.
it encoded with subs in correct place
but no audio
uninstalled ffshow and file loads in tmpgenc, but that's no good!
subtitle problem
By cloudsong in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2011, 17:18 -
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 10:44 -
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 04:32 -
Subtitle Problem
By simonrule in forum SubtitleReplies: 1Last Post: 10th Oct 2009, 18:59 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
