    Jun 2001
    Does anybody know how to do this? for example, I have a chess board on the compuer, and the chess board displays the moving step each 3 seconds. Is there any easy way to convert the graphics chess board display into VCD format?
  2. Why would you want to do that?
    Lotus screencam / MS Screen cam as well. both will work for saving it as an AVI file. Later you would encode it into an MPG file and save it to a "VCD"
    Or you can use a Video card with video/TV out put built in and save it to your VCR then use a vid Capture card to encode it to an MPG on the fly.
    Why ???
    Dec 2000
    Homebush, NSW, Australia
    Snagit is a good program for turning whatever happens on your screen into an AVI movie. You then just need to convert it to VCD using the TMPGEnc encoder.
    Snagit is here:
    http://download.cnet.com/downloads/0-10077-100-7862726.html?tag=st.dl.10001-103-1.lst-7-1.7862726
    Graham
    Jun 2001
    Thank you guys for the help. That's exact what I need.
    BTW, does anybody know how to convert an avi movie (1 frame/s) to a slide show? As well known, a slide show can have higher resulution than VCD movie, and use less space compared to a 1 (frame/s) avi encoded mpg1 (become 29.97f/s).
  5. most vid capture devices come with some sort of video/image capture/editing/darkroom software, or you can use Videocapturix and keep hitting the button or set the timer for 1 sec intervals . Just make sure that you set it up for "Multiple image capture" (with progressive names, ex 001.jpg, 002.jpg)
