  1. First timer here...be gentle!
    I have a 712 MB DIVX AVI movie.
    576x256
    23.976fps
    In EZ CD Creator it says that I can't burn it to VCD because the Frame Size is unacceptable.
    So I,(in my almighty wisdom)went into TMPGE and reset it to the standard 352x240 which I know is the NTSC standard.
    Not only did it take 14 hours ...but it ended up with no audio and a huge file of 2.5 gig!
    Any assistance would be appreciated.
  2. Follow these step by step and you should be all set!
    http://www.vcdhelp.com/tmpgenc.htm
    Good luck
