For whatever reason, I prefer to save movies on a DVD as mpg files. I
often use ISOBuster to extract and filter just the mpg files and then
join them together with CombiMovie. This method has been working well for me, but...... Two out of three movies on my last burn were not watchable due to rapid vertical roll on the TV. When viewed on the 'puter with Media Player Classic, they looked fine. My DVD player usually plays
anything you stick into it. Any suggestions?
Sounds like you have a PAL mpeg that differes from the NTSC (American) standard. I've run into this myself a few times, but since my DVD player accepts both types it will play them no problem.
Check your player to see if it has a similar setup, you might be pleasantly surprised . . .
Post back and let us know what you find.
Cheers!
TTWC"I've got a present for ya!" - TTWC -
Thanks. That was it. My DVD has PAL, NTSC and Multi. It was set on Multi, which I imagine is supposed to figure out which format to use. I set it to PAL and the TV started rolling like crazy. I had a hell of a time getting it back because it was rolling so fast I couldn't read the menu. Finally got it set to NTSC and they played fine. Thanks for your help.
DVDFlick burning question
By videodude1966 in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2009, 13:08 -
Question on burning CD
By tee jay in forum MacReplies: 2Last Post: 9th Oct 2008, 00:27 -
Burning question about Studio 10
By jimlong in forum Authoring (DVD)Replies: 1Last Post: 25th Sep 2008, 14:58 -
burning question...:-)
By Gunny in forum DVD RippingReplies: 12Last Post: 23rd Sep 2007, 17:54 -
ImgBurn burning question
By yogart in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 01:57
