I have been making vcd's and svcd's using various templates, but have one annoying problem.In the dark shadow areas of any movie you can really see the large blockiness of the pixels...what is the best solution or setting to fix this? other than that all looks fine...thanks, John
This is an artifactural problem. The gamma of your PC monitor is probably set incorrectly, exaggerating the difference between dark colours --> appearance of dark "blocks".
If you use Adobe Photoshop, it comes with a tool that adjusts the gamma on your screen.
If your TV is correctly setup (in terms of brightness and contrast), those dark "blocks" shouldn't be apparent.
Regards.
Michael Tam
w: Morsels of Evidence
Converting YV12 to anything else causes inexplicable blockiness
By Asterra in forum Capturing and VCRReplies: 13Last Post: 19th Apr 2011, 06:02 -
m2ts to xvid or h264 always gets blockiness
By ubulord in forum Video ConversionReplies: 29Last Post: 24th Dec 2010, 12:18 -
Looking for a video editing feature similar to "Shadows/Highlights" from PS
By vitwa in forum EditingReplies: 5Last Post: 6th Mar 2010, 17:21 -
Blockiness in a running water scene
By Umen Pich in forum Video ConversionReplies: 10Last Post: 20th Nov 2008, 10:32 -
Bigger factor for blockiness/compression artifcats
By pannayar in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:47
