Just as the title says. I have an external 120 gig. It's equally partitioned, using partition magic. So it's an F and G drive and for some reason the G drive works slower. By slower I mean, as an example, when I analyze my disk for defraging G always takes about twice as long, even when both have just been defragged. Both drives have almost the same amount of space. I've done a virus check, spyware check...nothing. I also did a disk check, but it turned up nothing. SO...what could it be?? I just don't wanna have to go through the pain of saving everything to another PC and the formatting...![]()
Smile
Smile
Generally one partition will be slower than the other simply because the disk reads more quickly towards the centre. You will notice a difference, but 100% seems out of order.
Other factors - block size, as mentioned, also file size (a large file reads quicker than lots of small files taking up the same space)Read my blog here.
HD with harddrive?
By Cabal2000 in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Dec 2010, 23:50 -
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 11:09 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
