Using Panasonic DVD Recorder to transfer SKY + progs or VHS to PC, edit then re burn. Was getting a lot of coasters thru my recorder not liking the media I was using, reverted back to DVD RAM disk and drag and drop to the HD. That started giving probs too, smart ripper is no use cos the panny doesnt seem to record in UDF mode (dvd decrypter asks if a valid dvd is present) so have to rip ISO mode in decrypter. How do I go about editing from here? I use TMPGENC DVD Author to make chapters etc.
Stevie
Stevie
Glasgow -
I have the same setup and I just copy the files directly from the RAM disc to the HD, no problem. The only time I had difficulty was when InCD was on the HD and it blocked my from any access to the disc. Totally uninstalling it solved the problem.
Still a few bugs in the system... -
Chas I said in another post, sometimes Im getting a split screen either watching the mpg in winamp or when making chapters in tmpgenc. I tried adding the iso to deamon tools and then adding the video to tmpgenc dvd author and i got the error 'only 1 file type or aspect ratio either 4;3 or 16:9' do you think this is the problem cos my dvd recorder may be set to record on widescreen?
StevieStevie
Glasgow
Non-experimental thread on best known VHS > BD / DVD methods
By _yo_wasup_ in forum Newbie / General discussionsReplies: 14Last Post: 17th Feb 2010, 15:28 -
VHS to DVD 4 methods?
By sonomablue in forum Capturing and VCRReplies: 73Last Post: 4th Sep 2008, 21:08 -
PIPO methods
By vlad247 in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Jun 2008, 02:43 -
Help with converting BBC HD Stream to DVD (Normal methods won't work)
By Killer3737 in forum DVB / IPTVReplies: 3Last Post: 30th Jul 2007, 09:23 -
Are there any methods to get a Ford oem Navigation unit to play dvd video?
By marc32 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 22:11
