I just bought my new computer, new everything, including a Geforce 6800 Ultra. The problem I have is when I play movies, the color is faded out, and sort of negative looking. The only way to fix it it seems, is if I open up the movie in one player (like windows media player) and then open it up again in like Winamp or something. The second time I open it, its perfect. I have downloaded K-Lite codec pack.
This happens with any sort of movie, except for .mov it seems. DVDs, mpegs, avi, all are glitched. I have downloaded the latest NVidia drivers, and everything else looks fine, im on 32 bit color and all the games I play are fine. Any help?
Did you install the CODEC pack? All of it???Originally Posted by Ignis
If you install the entire pack all sorts of bad things can happen when conflicting CODECS cross up. You should only install CODECS from the pack as you specifically require them.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
To fix the problem all you have to do is go to color correction in the
NVIDIA driver software go to Apply color changes to and select "All" and
then click Apply.
This should fix the video being too bright with the normal drivers by
default.
To locate that option: Control Panel -> Display Icon -> Settings Tab ->
Advanced Button -> GeForce Tab -> Popup Window to the left, Click on Color Correction
The newest drivers ( Forceware 77.72) for geforce cards causes the gamma setting to be set too high by default for overlay setting which makes video's look washed out.I think,therefore i am a hamster.
Is It Possible To Create A Custom Color From A Picture, For Text In Paint?
By V Bot in forum ComputerReplies: 10Last Post: 1st May 2011, 23:00 -
Standard Def DVD Movies With Best Picture Quality?
By avkhatri in forum Off topicReplies: 2Last Post: 8th Jul 2009, 18:29 -
tuning picture cleaning off color tubes?
By BroomQueen in forum DVB / IPTVReplies: 8Last Post: 8th Dec 2008, 09:01 -
Lg 42 lg 3000 color problems
By rambobambo in forum DVB / IPTVReplies: 3Last Post: 9th Oct 2008, 17:23 -
captured video has bad color problems
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 05:24
