*Sorry if this may be a bit confusing*
I am using Dvd-Lab Pro. My first question is, how to add multiple tv shows in a dvd. I have read the guide on the mediachance website, but it is not clear on what i need to do.
My second question is, is there a way to add a subtitle file for each epsisode to a dvd, so that i may have to option of enabling a subtitle file that matches its episode OR the dvd will automatically enable the subs when i choose an episode.
To make it more clear:
I have these korean episodes and the subtitles are not hardsubbed, they come in .srt files (subtitle files), and i would like to add 2 episodes per dvd. I do not want to hardsub the subtitile files into the .avi's because it just takes way to long. So is there a way to make a menu where it will have an option of enabling the subtitle to the episode that i am about to watch OR have the dvd enable it for me when i play the episode(s)
Right click in the top left window, add movie.
Check the guides on the mediachance website, there's a good one for multiple subs/audio tracks.
Yes, there's always a way
Cheers, Jim
My DVDLab Guides -
And to answer your question on subtitles:
Once you have put each episode within its movie container, double clik on one of the containers: you will see its timeline with lines that say video/audio/subtitles
Double click on the subtitle line to bring up the subtitle app, press load button and point to your subtitle for this episode (srt supported). Once you re finished, do not forget to generate the bipmaps. There s a check box for you to make the subtitles permanent or selectable (I always prefer to make them selectable - more cool).
Repeat for each episode and everything should be fine.
Multiple subtitle files into utf8
By fits79 in forum SubtitleReplies: 12Last Post: 3rd Jan 2022, 11:00 -
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
Help with MKV files with multiple audio and subtitle tracks.
By razzn in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 17:59 -
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 03:25 -
Merging multiple differently formatted text subtitle files?
By fvisagie in forum SubtitleReplies: 9Last Post: 18th Aug 2008, 15:23
