Hi
Client send us DLT tape. Tape was prepered for CSS (not encrypted - only marked) but client didn't knew that - authoring studio mistake. We send e-mail to our client: DVD should be css protected or not? They said no. There was no time to wait for another tape (newspaper insert).
Finaly my question: If someone know software that could copy DLT without CSS - help me, please (or maybe some tricks
Regards
Bartosz
it is an image file, just unload the file with your dlt tape software (novaback for example , or prassi even) or maestro or scenarist or dvd studio (Sony DVDA also can write DLT , but im not sure on reading them) .
you will have to reload it into authoring app and remove CSS check , also you have to RE-IMAGE file as sector size will be wrong
you could always just have them ftp a new image file -- should take overnight on most decent connections"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
since you dont have the elements ussually with the dlt , it is best to redo it as the chance for error is pretty good otherwise ..
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 18:11 -
Blu-ray ripped files to hard drive in Folders not un ISO Image
By judgmentday in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2008, 14:26 -
Can ImgBurn Make an Image of a Hard Drive on a Computer?
By drstew in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2008, 07:00 -
Any free software to wipe a hard drive?
By PhoneMatt in forum ComputerReplies: 19Last Post: 5th Mar 2008, 09:35 -
Transfer miniDV to hard drive. Does it matter what software is used?
By vid83 in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2007, 19:08
