  1. after using the registered svcd2dvd for a week now i have come across a problem with it, when i select it to open all that happens is that it shows up in the taskbar and that is it, when i choose to send the error report i get these details
    C:\DOCUME~1\Mark\LOCALS~1\Temp\WER65C.tmp.dir00\SVCD2DVD.exe.mdmp
    C:\DOCUME~1\Mark\LOCALS~1\Temp\WER65C.tmp.dir00\appcompat.txt
    does anyone have any tips please?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There may have been a change to your system. If you double click on the "SVCD2DVD demo.exe" file in the SVCD2DVD folder you can redo the registration process. This should solve the problem.
    Chris
  3. thanks for that, all i needed to do was restart my system for some reason, i had already done this since installing Svcd2Dvd but there must have been something wrong.
  4. P.S all fixed now
