  1. Hey guys I'm trying to author several epsiodes of a tv series onto one dvd. I have four seperate epsiodes, and each episode has an m2v video file and ac3 audio file. I add the first m2v file and ac3 file and cut my chapters and i get no problem. The problem is when I try adding the second m2v file i get this message:
    The existence of audio differs from the present track.
    The existence of audio has to be standardized on the track.
    There is audio on the present track
    I clicked cancel and tried adding my ac3 audio
    When I tried addin the audio into TDA I get this message
    The audio channel mode "stereo" is not compatible with the current track.
    The channel mode of the current track is "6ch".
    It is necessary to standardize the channel mode on the track.
    Re-encoding from this audio format to the audio format of the track is not supported.
    any ideas what I can do to sort these problems out???
    You can't mix different ac3 audio for same track/vts in tmpgenc dvd author. Just make a new track and add the episode.
  3. will do, thanks
