Results 1 to 10 of 10
  1. I left my pcs for about 4 hrs and when I came back to them the internet connection on them both had failed and I can't get it back. IE, Firefox, eMule and Bittorrent all stopped working.
    One PC is ethernet the other wireless, and both Firefox and IE have had their home pages changed from google to mozilla.org.
    Neither pc will access the internet unless I change accounts - luckily I have two setup on the laptop.
    What the bloody hell has happened here ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Uhm... 2 questions.
    1) have you talked to your ISP to make sure its not an issue on their end
    and
    2) how are we talking now?
  3. Switching users on my wireless laptop allows me use the internet and the router reports my ADSL as connected at the right speed, even my desktop (connected via ethernet) shows the internet connection Icon.
    I'm in work at the moment
  4. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Very odd. not sure what to say here.
    Uhm... yeah both user accounts corrupting at the same time seems unlikely.
    Hrm... maybe there is some new hack out there? Your machines all upto date?
  5. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    You try power-cycling your modem? Occasionally my DSL modem chokes up on high-bandwidth ports, especially when more than one computer is connecting through it. Make sure to leave it off for a good 30 seconds or so and the power it back up again.
    FB-DIMM are the real cause of global warming
  6. Originally Posted by rallynavvie
    There is no problem with either the modem or the router as it works fine by switching users on the laptop.
    I've just noticed something quite horrible. Whilst searching through the router options i noticed a screen that showed users connected to the router, I had my Acer (my laptop) Server (my desktop) and something called Snoopy which was Time Expired - anyone know what the hell that is ?
  7. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    yeah, it's your neighbor.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  8. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Or a war driver.
  9. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I highly suggest you reconfigure you router to only accept connections by known mac addresses.
  10. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    And turn off SSID broadcasting. That's the easiest way to prevent random folk from trying your network. You just have to remember what your router's SSID is when trying to add a new connection but that should be simple enough with one wireless network. Also make sure to at least use WEP encryption. WPA is a better option if you've got it.
