When I burn my DVD using Nero burning ROM, I encounter this problem (here is an excerpt of the log file)
3:33:47 PM #25 SCSI -1135 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03980000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x32 0x4D 0x03 0x0C 0x0C 0x00
3:33:47 PM #26 CDR -1135 File Writer.cpp, Line 311
Write error
3:33:47 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
3:33:48 PM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
3:33:48 PM #29 Text 0 File DVDR.cpp, Line 2632
EndDAO: Last written address was -1
3:33:48 PM #30 CDR -1135 File WriterStatus.cpp, Line 167
Write error
3:33:48 PM #31 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
3:33:48 PM #32 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5,540 KB/s)
I don't know what the error means but the DVD remains unused and can still be used.
I've encountered this problem before but after some time, it started burning again. But now, my burner is 'sick' again with this illness.
Please help. Thanks
My burner by the way (as it says in the log):
Recorder: <HL-DT-ST DVDRAM GSA-4082B>Version: A201 - HA 1 TA 1 - 6.6.0.3
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
What exactly are you trying to burn? Have you tried different media? Line 6 of your error log above shows that NERO is getting a media error from you drive. You could have a bad drive or bad media. Or Nero could just be corrupt and needs to be uninstalled and reinstalled with the latest patches.
Google is your Friend
Program to burn only select portions from a dvd to blank dvd?
By cv50 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2011, 20:17 -
How to get started burning blu-ray movies
By ace23 in forum Blu-ray RippingReplies: 9Last Post: 17th Sep 2010, 16:33 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 03:18 -
Burning Failing in Nero 7
By Osaka in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2007, 15:03 -
Newbie Burning Failing
By mearm in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 04:40
