Probably a silly question with a basic solution, but here goes: When I was using Win 98 with media player 6.4, the icons for Mp3's, wav's, mpeg's and avi's were all different. For example, mp3's had the little blue speaker, wav's had the yellow speaker, mpeg's the blue camera etc etc. It made it easy to identify the file without using other means. I currently use Mediaplayer 9 in Windows XP - the little rainbow icons tell me nothing!
Does anyone know how to get the old "win98-media player 6.4" style icons for media files in Win XP-media player 9? THANKS!
On a window folder menu, Tools >Folder Options > File Types. Left click your filetype, then Advanced > Change Icon. You can browse around to find substitutes.
You may need some icons to substitute. You should be able to download them somewhere on the net. Put them in a folder that you can easily find when you browse for new ones and change away. Some filetypes are generic, so you may not get exactly what you want, but give it a try.
Haali Media Splitter tray icon gone
By SvenVolfeid in forum Software PlayingReplies: 4Last Post: 7th Feb 2011, 07:46 -
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 10:54 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 05:47 -
question re wd hd media player
By julie_152 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2009, 12:46 -
CCE, OGM and Icon in Systems Tray Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 6th Jun 2008, 14:01
