Anyone knows why do I get this strange error trying to convert an MPEG1 source?
BTW I do have the MPEG audio codecs.
Have you tried a different conversion tool? You may not have the exact codec your current tool is expecting to find.
Google is your Friend -
I've never used the DivX converter. I would expect it should tell you somewhere which codecs that it requires. If not, there is a link to DivX support on the error message.
You could also try using codec sniper and see which of your installed codecs are invalid.Google is your Friend
good divx converter
By bigmacsexgod in forum Video ConversionReplies: 12Last Post: 19th Jan 2010, 14:35 -
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 14:00 -
Divx Converter
By jrodrigu123 in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 19:14 -
divx mobile converter
By sarmin in forum Portable VideoReplies: 1Last Post: 24th Mar 2008, 21:56 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28
