  1. Member vhelp's Avatar
    Mar 2001
    New York
    After using the search engine here, I could not find much
    info on my needs for a vdub filter to add text anywhere's
    in my video ...
    I know you can do it in AVIsynth scripts (though I can't
    remember the filter() command for it, but..
    Is there a virtualDUB filter to write text to each frame ??
    I know there are subtitle() filters for vdub, but I was
    looking for something that I could use through vdub, if
    I have no plans with using AVIsynth in any way.
    With vdub, I would like to add text at will, in any frame,
    and that includes other text such as Frame; Color space;
    Resolution; pixel info; etc.
    Any help would be appreciated, thanks.
    -vhelp 3429
  2. I used Neuron2's Logo Filter quite successfully.
