Does anyone have a good workflow for converting a PAL avi movie into a demuxed NTSC mpeg2 so I can burn it?
I've looked around and tried ffmpegx to no avail. Is it even possible?
It doesn't look like it converts pal to ntsc, but it could be useful. I'll check it out, thanks.
with ffmpegx it is possible, but you are probably running into
needing to do invert mapping, as something may be problematic wih the .avi.
I've done one, and it does take a LOONG while,
but you can use ffmpegx to accomplish it."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
i dont think its an avi issue. How would I go about this in ffmpegx?
-Drop avi on ffmpegx
-Select DVD mpeg2enc or DVD ffmpeg preset
-Go to the video tab.
-Change the video size to 720x480, and change framerate to NTSC or NTSC film.
I've had more success doing these conversions using NTSC film with 3:2 pulldown than going directly to NTSC.
The only tricky consideration is figuring out the resizing, possible cropping and letterboxing. If your avi has no letterboxing then the automatic letterboxing of "decode with quicktime" will do the trick either with DVD ffmpeg or DVD mpeg2enc. If however there is some letterboxing present it's probably preferable to go the ffmpeg route and manually crop and/or letterbox your video in the filter tab. Note that if you add, for example, letterboxing of 60 both top and bottom then you have to set your video height to 480-60-60 so that the final total is 480.
Good luck
Alph
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 08:43 -
NTSC(?) avi to PAL dvd
By Instant Martian in forum Video ConversionReplies: 34Last Post: 14th Mar 2009, 16:32 -
Can AutoGK convert PAL Region 3 dvd to NTSC .avi?
By bloomcounty in forum Video ConversionReplies: 14Last Post: 20th Nov 2008, 20:31 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 17:15
