Hi everyone.
Im creating a dvd about my village with 4 main movies and a simple menu.
Here what i would like to create if possible:
Whenever the menu button is pressed i would like the dvd to show a short video clip(random) before the menu of the dvd is displayed.
Each short video clip would be about a monument or place in my village.
Is this possible?
I use dvd lab pro, been using it for about nine months and feel at ease with it.
All my video sources are ready to use.
I love it when a plan comes together!
Ricardouk, I understand that a menu dvd works with connections that means every time you push a bottom it will go to a specific destination,so I don't know about ramdom play. I also been using dvdlab pro for a while if I find out anything about I'll get back to you.
hi ricardouk
its easy
link the menu button you want to use with this small clip instead of the main movie.
then in connections window find this small(s) clip,you ll see a very small circle
in the end of it,right click on it and chose "draw connections",then holding the left mouse button you can join this point with the begining of the real movie.
like this when the small clip will finish the real movie will start,there is no need for direct connection to the movie from the main menu.
rgrds -
Hi SATSOK
thanks for your help and time.
What i want to achieve is different from what you wrote, your solution will enable me to have a small videoclip before main movie(very esasy)
what i would like to have is the showing of a small random clip everytime i watched any of the main video clips by pressing the "menu"button of the dvd player, not the menu button on dvd lab itself
sorry if i mislead you
thanks again for your timeI love it when a plan comes together! -
With this scheme everytime menu button is pressed a short clip is shown(movie4) before it sdisplyas the main menu
What I would like to do, is that movie number 4 becomes a random clip
thanks
Originally Posted by GordRocks at MMBforums
Thanks Gord
(Just noticed i reached the 200 posts mark)I love it when a plan comes together!
DVD Lab Pro Menu Resolutions
By Anonymous344 in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2010, 17:11 -
DVD Lab Pro menu help
By stantheman1976 in forum Authoring (DVD)Replies: 12Last Post: 27th Jan 2009, 17:27 -
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 04:52 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03 -
DVD Authoring with DVD LAB PRO doesnt create all files
By SSJ4Thiran in forum Authoring (DVD)Replies: 16Last Post: 18th Feb 2008, 10:03
