Hi,
I've got a ripped dvd on my hdd.
I'd like to create a menu for that dvd and make chapters for the film.
The problem is, that most author tools that I know reencode the input, but my material is already in dvd format so encoding it again would mean a loss of qualtity.
The only tool I know, which supports vobs and doesnt reencode the vobs is tmpeg dvd author. but there you can only create very simple menus.
Can you recommend a tool to me?
Thanks in advance
The few that I've used give you the choice to encode or not but it is often hidden. Ulead DVD Workshop, for example, lets you choose the final output quality from a list of presets. It then uses settings defined in the preset that you chose to encode the video. However, you are able to manually edit and/or create more presets. As long a the preset matches your input video, no encoding will take place.
Google is your Friend -
Another one to try is TMPGEnc DVD Author not only won't it encode your files it can not encode them as it has no encoding ability. The only ting it can do is take for example VCD audio and redo it for DVD audio (48Khz) and if you have the AC3 plug-in it can also convert MP2 or LPCm audio to AC3 2Ch.
Cheers -
tboneit: reread the first post again....tmpeg dvd author sounds like tmpgenc dvd author...
Baldrick: You are right, Damn sun glare!
OTOH I've made some decent looking menus using a dance number from one of the shows on the disk as a motion background where thet're singing and dancing away. Put the buttons where they showed all the time.
Anyway, Sorry bout that.
Cheers
Need FREE DVD Authoring Software (Which Authors VOBs & Allows Menus Etc)?
By larrytxeast in forum Authoring (DVD)Replies: 15Last Post: 26th Jul 2010, 13:07 -
Free Software to rip multiple PGC's in one hit to individual vobs
By Ads79 in forum DVD RippingReplies: 2Last Post: 24th Apr 2010, 04:25 -
Authoring VOBs into Titlesets with Chapters
By matthewjohn23 in forum Authoring (DVD)Replies: 3Last Post: 16th Jan 2010, 14:24 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 11:25 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30
