Hi just got Pinnacle Studio 9 + for Windows. I have a canon mvx250i camcorder. When I ask pinnacle to capture the video it says "unable to capture PAL not enabled".
Now I know I need to change to PAL from NTSC however the button is greyed out for some reason stuck on NTSC.
Ive tried changing all the options but cannot change to PAL.
How can I change it to PAL please thanks.
I have the same camcorder and have never had the trouble you are describing.
Suggestions of things to check:
1. Regarding the TV Standard setting option - Quote from yhe Studio manual "If you purchased your Studio product in North America this option is permanently set to NTSC" - check with whoever you purchased the software from.
2. Is your camcorder PAL ? - I know a friend of mine imported one from Hong Kong cos it was cheap and it turned out to be a NTSC model.
Hope the above helps. -
Sounds like PS9 is bought in US and camcorder in EU ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Can Pinnacle Studio Ult. 14 perform a PAL-TO-NTSC CONVERSION?
By MISS CHIEVOUS in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2011, 19:51 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
pinnacle studio 11
By serega in forum Latest Video NewsReplies: 14Last Post: 13th Sep 2007, 18:14 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56 -
Importing PAL into Pinnacle Studio 11
By yifan in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2007, 16:11
