OK to start off im using virtualdub 1.6.5 to combine a 2 part xvid movie. the first time i tried it said that the audio was in mp3 vbr format so i couldn't append them...ok no problem, extracted the audio to wav files for both parts and resaved the avi's with a 128kbps cbr mp3 audio stream.
tried to append the avi...now the audio where the second part of the movie begins is not lining up. but if i play the separated part the audio syncs perfectly. i notcied that the length of the audio track is not the same length as the movie...what can i do to get the audio to sync after i combine the avi.
When you open your XviD movie with mp3 vbr audio, VDub issues a message. Ignore it. VDub will open your video like a good boy. Click Video>Direct Stream Copy and then File>Append segment and open the second XviD movie similarly. Click Save As and save with a new name in the location of your choice. See the result.
Report back what happened, please
Thanks. -
Did what u said and Vdub displayed the following message
Connot append segment "File": The audio streams have different sampling rates (12542.00000 vs. 12494.00000)
I tried to see if vdub could append the avi if i put the audio in full processing mode so that it would change the audio from vbr to cbr...DIDN't work same message displayed -
Yes, the parameters (video frame rate and audio sampling rates) need to be same for joining media files in VDub. Download SSRC v1.30 and equalize samplerates of your audio.
Thanks.
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
Audio sync issues when combining videos from Youtube
By The Invisible Hand in forum EditingReplies: 5Last Post: 6th Oct 2011, 13:43 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
