hello
Downloaded the above.
There is a zip called plugins within the file.
however theres no docs I could find on if they are to be unzipped and if so were to. same directory or what.
Mark
They are all avisynth plugins and they can go anywhere you like, as long as you supply the full path to them in your avisynth script. With that said, you can also put them in the 'auto-load' directory, which is typically 'c:\program files\avisynth 2.5\plugins'
How to encode DVd to DIVX with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 32Last Post: 21st Nov 2008, 04:02 -
How to convert DIVX/XVID to DVD with gui4ffmpeg
By gui4ffmpeg in forum User guidesReplies: 41Last Post: 12th Nov 2007, 12:35
