I just received a DVD from family in Italy. It is a regular sony DVD-r disc. It does not play on my dvd players. I tried to use Ulead Movie factory to convert the disc. The copy came out fine and plays on my dvd home player, but there is no sound, just video. I also tried using dvd Shrink thinking maybe it was because of the region setting but still no luck. How do I copy this DVD and get it to work in my home DVD player with the audio?
Also it plays fine on my computer.
please any help would be appreciated.![]()
Results 1 to 12 of 12
a sony DVD-r disc would not have normally any region codes on it ...
it is PAL and you have to convert it to NTSC or get a dvd player that converts ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
PAL/NTSC issue as BJ_M mentions.
Also, media compatiblity. Try burning with different media. -
Also, audio may be mp2 and your DVD player may not support that.
Does the original play OK on your PC?There are 10 kinds of people in this world. Those that understand binary... -
yes the original plays back on the PC and the sounf also. When i made a dvd using movie factory the copy played back with no sound. How do I convert the sound?
why are you using movie factory anyway ?
do you just need to copy the disk ? then just make a copy ....
do you need to convert it to ntsc ? then use the right tools ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
The simplest solution is to buy a $35 DVD player that can perform the PAL to NTSC conversion on playback.
Maybe it's just me.... but he said the video played fine & it was the audio that he is having a problem with . i have never had a problem with "PAL" audio, if there is such a thing
Originally Posted by kx5000 -
PAL DVD officially supports MP2 audio, NTSC DVD does not. Some (very few) NTSC DVD players will not play MP2 audio.Originally Posted by Noahtuck
With NTSC DVD's you can have MP2 audio, but you can not just have that and no other audio on the disc. NTSC discs must have at least either PCM or AC3 audio on there, you can't just have MP2 audio.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Ntsc dvd can have just mp2 audio since most newer dvd players will play svcd,just very few wont play mp2 as already mentioned.
Huh.... i have done a ton of PAL to NTSC conversions and have never had a problem with audio....... just video if the player would not convert the video to NTSC.... which is why i always do the conversion (and not that voodoo patch conversion
, a true conversion) and the only time i have ever had a problem was with the video, like if a standalone player would not convert PAL video to NTSC video, the audio was always fine..... and i just convert the video seperate and don't touch the audio at all.... and have never had a problem... and i have tried every method people have come up with... and found only one to work!!! that seem's to be true 8)
I have not received the registration code.
By oyak in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2011, 00:20 -
Upscaling of received signal.
By Cole in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Apr 2008, 08:42 -
mini dv from europe (italy) problem
By bill71ok in forum Newbie / General discussionsReplies: 2Last Post: 27th Oct 2007, 12:56 -
problem with mini dv from europe (italy)
By bill71ok in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Oct 2007, 10:30
