How do I use alpha channels as a mask in after effects, all I've heard is something about orginal footage multiplyed by alpha channel = masked footage then masked footage + premultiplied by alpha = final composite.
Could someone give me a step by step walkthrough on how to do this please?
Signed Croziaq
Hi,
I'll help you out, I've been using AE for years now.
Assuming you have AE 6+ Professional the easiest way is to use the auto-trace feature.
Select your layer with the alpha channel and go to Layer--? Auto trace.
Make sure you set channel to alpha and click the Work Area check box in the timespan area.
8)
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 10th Aug 2010, 00:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 20:16 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 17:07 -
How to make 'alpha elements'
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 24th Feb 2009, 10:02
