I use Subtitle Workshop to synchronize the subtitles. The major problem with this is:
The movie should be allowed to be played continuously. What I mean, is that, the slider on the navigation bar should not be moved if correct frame rate is needed. If the slider is moved the frame rate changes with a high variance(difference) in comparision with the actual frame rate. So, the wrong frame rates will be applied to the subtitles in case the slider is moved.
For example, if I synchronized first 10 minutes of the movie, left it for a while, and came back again after some time, this time, I cannot start synchronising it from the point where I stopped it previously(i.e., at the 10 minutes mark), instead I've to start the movie from the beginning, wait till 10 minutes of the video played, and then start synchronising thereafter.
In case, I use the slider and took the position to the point where I stopped previously, the frame rate changes. To be more meticulous in explanation, if the stop point was 00:10:22,234 actually, and this time if I use the slider and move to that point of the video(where I stopped previously), the frame rate shown would be something like 00:11:33,544. So, if you notice, in case I use the slider to get to the point, the frame rate shown will be false. It's not the actual frame rate which it is supposed to be. If now onwards I start applying this frame rate to the subs, this leads to absolutely wrong synchronising, coz later when I actually check the movie by playing it continuously, the subtitles start appearing at the wrong times after the first 10 minutes.
Can any one suggest me a method through which I can start synchronising subs from the point where I left before(by using the slider)?
	I have noticed that problem with mpeg files only.
 I have never encountered those problems with .avi.
 Haven't found the solution for that mpeg preview.
 But if you go to Settings, there is an option for external preview. I have never used it, but maybe it could be useful if you wish to experiment a bit.
  Convert pac subtitle to something that I can open in Subtitle workshopBy Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49
  Subtitle Workshop - not creating subtitle at current time locationBy botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09
  how to open chinese subtitle in subtitle workshopBy pcb in forum SubtitleReplies: 2Last Post: 28th Nov 2010, 17:03
  Subtitle Workshop 4 crashes when loading subtitle fileBy Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57
  Problem expanding subtitle time with Subtitle WorkshopBy Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Visit Homepage
				Visit Homepage
