hello everyone,
i wanted to find out how to properly change my PSX games from NTSC to PAL and vice versa. so i backed up my game as an image file on my comp, and i read that PAL4U does this procedure so i checked it out. i just wanted to make sure i was doing the steps right.
i clicked the first box and selected my image, than the second one, and the bar reached all the way to the end, now wat do i do, is my image changed? thanks![]()
Wow! You got shocks, pegs... LUCKY!
You burn it and see what happens it should have changed the regional hexcode stuff for you
Just make sure your tv is capable of supporting video from the new region -
is that the only way to know, to chance it on media... thanks
Wow! You got shocks, pegs... LUCKY! -
ok cool thanks
ill try it out... im currently out of CD-Rs so im buying some tomorrow morning, so ill try it out and post back in a day or so... thanks man :P
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
