Hello all. I received some good advice from some experts on this board a few days ago, and I am hoping you all can help me again.
I made a recording of a church conference using an old analog Hi-8 video camera. The recording is bad...the mic was too close to the audience and not close enough to the speaker, causing the speaker to be quieter than I would like, and the crowd's applause to be overwhelming.
Using Goldwave, I have imported my AVI files and improved the sound some using the simple compressor. NOw, I have saved the new audio as WAV files. What I am not sure of next is how to create new AVI files using the new WAV audio.
SOrry this is a foolish question. When I captured the video on my computer, I simply plugged the AV cables into my All-In-Wonder card and captured using MyDVD. I don't have any experience dealing with video and audio as sepearate pieces until now. Thanks!
Results 1 to 12 of 12
Use virtualdub and open it and browse to your avi file and open it,then click on video and choose direct stream copy and then click on audio and choose wav and browse for your new wav file you made.
Then go to file and save as avi with a new name.I think,therefore i am a hamster. -
Thanks for the tip. Sounds easy enough. Now....are there any other programs that do basically the same thing? I get an error when I attempt to open my AVIs with Virtual Dub.
[!] MPEG: File ended unexpectedly during parsing -- file may be damaged or
incomplete.
[E] Error: No video frames found in MPEG file. -
I could have sworn that a MyDVD capture, is an Mpeg capture, in which case, VirtualDub can't help you, since it's an AVI editor..I simply plugged the AV cables into my All-In-Wonder card and captured using MyDVD
However, VirtualDubMpeg could probably help you a little..It's just like VirtualDub, but with Mpeg support...
Good luck!! -
OK, not surprisingly I made a goofy mistake. All of my videos are actually in MPEG2 format. SO, I have my video in MPEG2 and now have nice WAV files for the audio. How to i "put these together" to create a new video (MPEG, i guess)???
Maybe it's that easy...I've tried downloading this program the past few days, and the download sites were down...but I've got it now. I'll give it a go. Thank you for your help!
You said you used MyDVD. I have MyDVD 6.0 Deluxe. With that version, you can add a background audio file to your DVD project. If you add your new wave file as your background audio file and then turn down (to off) your original video audio track, you can make a new DVD with the new wave file. To check for any audio delays, set the level of both audios to the same value and listen for echoes. If you saved your original DVD project, you probably won't have to reencode.
Should get that added to the "Tools" list and a forum url link as well.Originally Posted by celtic_druid
No sound when replacing audio
By konu in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2011, 20:10 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
help replacing audio on DVD
By fullbohr in forum AudioReplies: 3Last Post: 12th Nov 2009, 21:34 -
replacing audio on a dvd
By phillbrett68 in forum Authoring (DVD)Replies: 2Last Post: 7th Dec 2008, 02:00 -
Replacing MPEG audio.
By dfisher052 in forum AudioReplies: 3Last Post: 16th Oct 2007, 14:14
