Hi
I am using nero 6.6.014, DVD Shrink 3.2, DVD Decrypter 3.5.4.0 to burn a Traxdata DVD+R DL (2.5x) the drive is a fujitsu-siemens notebook NEC ND 6500A, AMILO PRO V8010 (Fireware 2.40) i got a ilegal disc before it starts to
burn with all three programs, any help would be great thanks.
'SFMMCX'-(17)
'atapi'-(0)
-'_NEC DVD+-RW ND-6500A 2.40'-(0)
Module sfmmcx.cpp Line 1795
An illegal request was received.
The disc can't be written. It is an incompatible format.
Status: 00020202
Command: 2a 00 00 00 00 00 00 00 20 00
Sense: 05 30 05
Info: 00 00 00 00
Specific: 00 00 00
Extra: 00 00 00 00 00 00 00 00 00 00
Nero CD-DVD Speed: Disc Info
Basic Information
Disc Type: : DVD+R DL
Book Type : DVD+R DL
Manufacturer: : Ritek
MID : RITEK D01 (001)
Write speeds:
Blank Capacity : 7.96 GB
: 8152 MB
: 8547993600 bytes
Extended Information
Layers : 2
Layer break : 3.98 GB
Write strategies : n/a
Disc Status : Empty
Raw Data
ADIP Information (11h)
0000 - E1 0F 32 10 00 03 00 00 00 FC FF FF 00 22 D7 FF - ..2.........."..
0010 - 00 00 00 52 49 54 45 4B 00 00 00 44 30 31 01 40 - ...RITEK...D01.@
0020 - 25 25 37 00 00 28 64 00 28 64 19 1B 0B 0B 0E 0F - %%7..(d.(d......
0030 - 01 00 00 00 00 19 1B 0B 0B 0E 0F 01 00 00 00 00 - ................
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 14/08/2002 15:03:36
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero API version: 6.6.0.14
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 14d
Recorder: <_NEC DVD+-RW ND-6500A> Version: 2.40 - HA 0 TA 0 - 6.6.0.14
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD+-RW ND-6500A atapi Port 0 ID 0 DMA: On
DiskPeripheral : FUJITSU MHT2040BH iaStor Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD+-RW ND-6500A E: CDRom0
FREECOM_ DVD+/-RW4B F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 502MB (514480kB)
Free physical memory: 161MB (165840kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.7.2005
NeroAPI
13:46:03 #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
13:46:04 #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
13:46:04 #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
13:46:04 #4 Text 0 File DVDR.cpp, Line 6128
Book Type counter: 500, Book Type selected in EEPROM, command version 2
13:46:04 #5 Text 0 File DVDR.cpp, Line 6128
13:46:04 #6 Text 0 File Reader.cpp, Line 127
Reader running
13:46:04 #7 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD+-RW ND-6500A running
13:46:04 #8 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
13:46:04 #9 ISO9660GEN -11 File geniso.cpp, Line 3297
First writeable address = 0 (0x00000000)
13:46:04 #10 ISO9660GEN -11 File geniso.cpp, Line 3297
13:46:05 #11 Text 0 File Burncd.cpp, Line 3230
Turn on Disc-At-Once, using DVD media
13:46:06 #12 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 4075247 (905:36.47, 7959MB)
13:46:06 #13 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO
13:46:07 #14 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: _NEC DVD+-RW ND-6500A, Media type: DVD+R9 Double Layer
13:46:07 #15 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
13:46:07 #16 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 4075248 (4075248) = #4075248/905:36.48
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4075248 blocks [_NEC DVD+-RW ND-6500A]
13:46:07 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD+-RW ND-6500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8346107904, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
4075248 | lead-out | 1 | 0x41 | 0x00
13:46:08 #18 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
13:46:08 #19 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
13:46:08 #20 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
13:46:08 #21 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 2.4x (3,324 KB/s)
13:46:08 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
13:46:09 #23 Text 0 File DVDPlusDualLayer.cpp, Line 595
L0 Data Zone Capacity set to 2037792 (1F1820h, 3980MB) -> OK, confirmed setting
13:46:09 #24 CDR -1205 File DVDPlusDualLayer.cpp, Line 622
Burning Layer 1
13:46:09 #25 Text 0 File DVDPlusDualLayer.cpp, Line 632
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
13:46:09 #26 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x0C800800
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
13:46:09 #27 Text 0 File DVDR.cpp, Line 6128
13:46:09 #28 Text 0 File DVDR.cpp, Line 6128
13:46:09 #29 Text 0 File DVDR.cpp, Line 6128
13:46:09 #30 Text 0 File DVDR.cpp, Line 5232
Drive: _NEC DVD+-RW ND-6500A
Book Type request [NEC]: DVD-ROM, write to RAM
select Book Type setting from RAM
Changing the Book Type was finished successfully, return code 0
13:46:09 #31 CDR -1211 File DVDR.cpp, Line 4929
Book Type set to: DVD-ROM
13:46:10 #32 Text 0 File DVDPlusRW.cpp, Line 655
Start write address at LBA 0
DVD high compatibility mode: Yes
13:46:12 #33 SCSI -1046 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x00C80000
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x30 0x05
13:46:12 #34 CDR -1046 File Writer.cpp, Line 311
Illegal disc
13:46:12 #35 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
13:46:13 #36 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
13:46:13 #37 SCSI -1046 File Cdrdrv.cpp, Line 1182
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
13:46:13 #38 SCSI -1046 File Cdrdrv.cpp, Line 1182
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
13:46:13 #39 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
13:46:13 #40 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
13:46:13 #41 Text 0 File DVDR.cpp, Line 6128
Book Type counter: 500, Book Type selected in RAM, command version 2
13:46:13 #42 Text 0 File DVDR.cpp, Line 6128
13:46:13 #43 Text 0 File DVDR.cpp, Line 5232
13:46:13 #44 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 2.4x (3,324 KB/s)
13:46:13 #45 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
13:46:13 #46 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
13:46:15 #47 Text 0 File DVDR.cpp, Line 6128
13:46:15 #48 Text 0 File DVDR.cpp, Line 6128
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17/08/2001 15:07:32
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 14/08/2002 15:03:36
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 11/03/2005 23:28:13 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
