I live in canada, have a PAL-tape and a PAL-vcr without an internal converter. so I got an external converter, but it is stupid and requires a 50hz compatible ntsc tv to display correctly. My tv doesnt have that i dont think. I wanna watch/capture it on the computer, but cant find software or option where i can select at how many hz i want the capture to be.. what do I do??
how do I select 50hz, or auto-sync, or whatever , so that the 50hz signal will be read at 50hz not 60hz like all software seem to be doing by default..
thanks alot to anybody who knows
To capture in pal you have to change the device setting to pal,i can do this on my capture card,in virtualvcr you would go to settings/video/device settings and choose pal_b.
thanks, but it doesnt work. I can choose pal_m, pal_n, pal_b and all the other pals in all the other software, but none of the pals work. the image flickers constanly. only if i select pal_60 does it stay okay, except the image flicker heavily in 15-30 sec intervals.
maybe its because og my video capture card. ATI AiW 7500 which says it's ntsc (on the box) and it also supports pal_m, pal_n, but when I choose those it doesnt change anything.
maybe the problem is that my PAL-VCR, which has ntsc playback, outputs at PAL at 60hz (im guessing) . and my capture card cant recognize it at 60hz, although it may have been able to do so under pal_m, pal_n if it were at 50hz like its supposed to be. -
Can you set the vcr to play at 50hz pal?
Originally Posted by markiz2001
If it has NTSC playback it will put out a PAL60 signal when playing a NTSC tape, which is 60hz. -
What version of MMC are you using?
Project Digital: Eliminate All Physical Media is finally underway!
Need help capturing PAL video input.
By Tobes in forum Capturing and VCRReplies: 10Last Post: 5th Nov 2015, 06:22 -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 03:36 -
selecting a DVDR/VCR combo w/ RF input
By SLudwig in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Sep 2008, 14:03 -
Selecting audio input in wavelab
By jcoops16 in forum AudioReplies: 0Last Post: 2nd Aug 2007, 15:53 -
Influence when selecting PAL or PAL 16:9 with TMPGEnc
By Purno in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2007, 04:24
