Hi,
I just bought a Tv capture card and I´m using VirtualDub with the Huffy video codec.....but the Quality is bad if I put the size on 288 252 voor VCD. The bodem part of the video is green the rest is almost a mess..
Can someone tell : what did I do wrong or perhaps I´m using the wrong settings. I hope someone can help cause I have a lot of vhs that I have to put on my PC to make VCD´s.
Thanks already
Did you change the settings in Huffy towards best quality? I would suggest that. Or you can try MJEG codec set to 18.
Macros -
huffyuv is a lossless codec. there is no quality setting, only compression. at any rate it sounds like macrovision to me
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 14:56 -
Why is my YouTube video bad quality?
By vid83 in forum Newbie / General discussionsReplies: 15Last Post: 16th Feb 2011, 17:09 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 16:33 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 20:07 -
Bad video quality
By windofice in forum Newbie / General discussionsReplies: 8Last Post: 16th Jan 2008, 22:20
