Results 1 to 14 of 14
    Mar 2004
    OK A couple of easy questions *hopefully*
    I have a 60MB MPG that I wish to resample for e-mail purposes to a 5-10MB file. Suggestions??? What program???
    I have already used Videoredo to strip this file from a bigger one. When I look at Gspot it sees no audio but when I play through a couple of different players the audio is fine...
    Y
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    Use virtualdubmpeg2 to convert to divx or some other codec.
    Though remember you'll get quality loss if you compress too much. Just test and see what is acceptable to you
    Kevin
  3. Member Cornucopia's Avatar
    To keep the bits per pixel (quality) up, you may want to drop you resolution to 1/2 or 1/4 of current size.
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd use Windows Movie Maker, the "High quality video (small)" template and output as WMV.
    If in doubt, Google it.
  5. Member jak_omo's Avatar
    Jun 2005
    İstanbul Country: Turkey
    wmv should be the best choice for good quality an small file size.
    darling if there is no place for me on your desktop, i'll waiting for you in the system tray
  6. wmv are suprisingly high quality for small files 512kbps
    just shy of 4MB per minute of footage
    did microsoft make the codec themselves or nick it off someone else
    it feels strange to hear people complementing a M$ product :P
    divx @800kb/s is pretty good too
    plus it has the advantage of being able to be cut easily without yet another reencode in virtual dub
    Mar 2004
    Thanks for all the suggestions. But since I don't have the source can I really convert the existing MPG???
    If I can could anybody give a tip which menu feature to use??
    Y
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    Yes just use virtualdubmpeg2 as you would with a normal avi file. Just go to file, open video file, and select your mpg file. Then choose the audio and video codecs you want to compress it too.
    Kevin
    Mar 2004
    Hmmmm...right now I can't even get the program open.... There appears to be no install...
    Y
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That's because there isn't an install
    Just double-click the virtualdub.exe file and you're good to go ...
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    or use something easier like DivX Converter or Dr DivX.
    Mar 2004
    Weird ...I searched the all the extracted directories and there is no *.exe
    I'll try a different source.
    Y
    Mar 2004
    OK trying to use VirtualDub and I get an error when I try and open either of the MPG files:
    "MPEG Import filter: Invalid pack at position 3: marker bit not set possibly MPEG2 stream"
    Ideas???
    Mar 2004
    Just an FYI....
    I ended up using Canopus Procoder and it had a great wizard that I used to step through and reduce the size of the mpg.....
    Y
