    Jun 2005
    Australia
    how long does it generally take to burn a dvd movie? it takes around 5 hrs for me- is that normal (using nero)
    just burn should take 6-60 minutes.
    but are you also converting?
    what is your video source? avi
    are you using nerovision express?
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Depends on what speed you burn at.
    8X will take 7-8 minutes
    4X will take 15 minutes
    2X will take 30 minutes and so on.
    Jun 2005
    Australia
    Hi, yes I just import the avi file , create a menu etc and burn using nero express.
  5. 5 hours doesn't sound unusual for an AVI->MPEG2 convert/burn on a P3-500 -- depending on the length and frame size of the file being converted. If you're talking about a 30 second clip 5 hours is long. If your're talking about an hour long video it's probably about right.
    Jun 2005
    Australia
    I was thinking of upgrading to a pentium 4, 3Ghz, Is that going to make a difference?
  7. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Yes. A processor upgrade will make a huge difference in encoding speeds. Consider also upgrading your memory too.
