Ok before you flame me and tell me to read the forums and other parts of the site, I did do that. I want to be able to convert a .mov file to a .mpg file to be able to play on my dvd player. Here is exactly what I did and what the outcome was.
First I did a google search and tried 2 different programs I found that way. One would only convert 5 min. and the other would convert only half of the file so that was a bust.
I first tried tmpgenc without the quicktime plugin and converted half of the file before I got an error saying bad format. I put the QTReader.vfp into the folder that had the other .vfp's and tried to convert the file again but it wouldn't even open the file.
I then tried divxtodvd and got an "invalid floating point operation" when trying to load the video.
Cinema craft would just not open the file.
eovideo produced this error "eo video - quicktime audio not supported (err=30702-0) converting terminated"
edit: I also tried rad tools and got the error could not open audio stream. It converts the file in about 10 seconds and no program can open it. (Right now though I can't view video without it being all distorted so for this program it my just be my computer, which I am currently working on fixing)
I will only need to convert this one file and won't have much use for video conversion after this so I will only be able to use free software or free trials. If someone could please help me I would greatly appreciate it. Thanks.
Export the file to an AVI (using Quicktime), then encode to MPEG-2.
Originally Posted by Afterburner
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Mov conversion help?
By Timbo78 in forum Video ConversionReplies: 2Last Post: 13th Sep 2010, 06:10 -
video conversion to mpg2/vob/h264..
By krohm in forum Video ConversionReplies: 14Last Post: 10th Jun 2009, 14:32 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
ffmpeg converts DV .mov to .avi, results run 5 times too fast
By sybariten in forum LinuxReplies: 1Last Post: 13th Jun 2008, 13:48
