  1. I have a a VIDEO_TS and AUDIO_TS folder and want to create a divx video to play on my dvd player. How can I do this?
    USA
    You might look into FairUse Wizard. It works very well for DVD to Divx or Xvid conversion. Whether that is compatible with your player is another question.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd start by checking the guides section and the tools section (both to your left). There's plenty of guides and tools on how to do this. Pick a guide, and a tool (or tools), have a crack, then post back if you have any problems
    If in doubt, Google it.
