Just used it i like it worked great
like the sound wave when file complete![]()
nice job
with this program i think your on a winner and will be able to retire![]()
thanks 4 the great surport
Results 1 to 15 of 15
No it is not out yet. A few people who have being helping me out are testing the latest version currently. Shortly that version will be on the users area. Thereafter it will have a demo version too.
FYI I have put a new build in the users area... It is pretty much there other than the assistance & help.
Just tried to download the test build but keeps coming up with page cannot be displayed.
Anyone else getting this ?. -
Mmm. Its my great ISP up to its old tricks....
Actually it wasn't. it was a typo! Sorted now.
Ok downloaded and get this each time i try to start the programe.
Also i have noticed that there is no option to add shortcut to desktop would be nice if it was there so we do not have to go start,programes etc etc ??.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: Index was out of range. Must be non-negative and less than the size of the collection.
at System.Collections.CollectionBase.System.Collectio ns.IList.get_Item(Int32 index)
at DevComponents.DotNetBar.SubItemsCollection.get_Ite m(String name)
at x3284ccece41ee22b.x210ff09a2516b1a7.x4e0e7161eb7bf 37d(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.2012.19550
Win32 Version: 2.0.2012.19550
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 4.9.6.0
Win32 Version: 4.8.1.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog. -
Did you try one of the other post RC9b builds? If so you may have a dnb.xml file in your SVCD2DVD v2 folder. You will need to delete this as there is a new button for the settings now.
I.e. Close S2D delete the dnb.xml file and then restart S2D.
Yes i did try one of the rc9b builds so what i have done is deleted the dnb.xml file and now works fine.
You wrote...You will need to delete this as there is a new button for the settings now.
Do i need to do anything in respect of this or not. -
In your case no as you have used the newer builds before.
People using builds post RC9B for the first time will need to set their settings again - especially the burning settings.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 10:35 -
the final insult...
By greymalkin in forum Off topicReplies: 15Last Post: 7th Apr 2009, 11:12 -
Final Cut Express- How To
By ker-plop in forum MacReplies: 2Last Post: 8th Apr 2008, 21:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 11:05 -
Final Burn
By jw2914 in forum Video ConversionReplies: 2Last Post: 6th Jul 2007, 17:01
