Hi to all!
I'm new in this world of photos and CD's, so i need to now if is possible to make a slide show with my photos to see in my DVD player. I don't have any DVD burner, so i need to make that slide show in a CD-R. I wish to add some music to that slide show.
Any sugestion?
Thanks in advance for your help!
There are good instructions for this in Toast Help.
There are two kinds of slide shows. One is where you simply drag the thumbnail photos from the iPhoto library to Toast. Toast will create a slide show without sound where the slides advance every 5 seconds (you can change that in Toast). You also can advance slides (or go backwards) using the chapter skip button on your DVD player's remote control.
The other slide show is actually a movie. You drag the photos to Motion Pictures (bundled with Toast 6) or iMovie and you can do zooms and pans of each image, plus add a sound track. This has lesser picture quality than the regular slide show.
One suggestion: If your images are very high resolution, use iPhoto to export them at, say 800 X 600 before dragging to Toast. Toast ultimately will make them 640 X 480. I've read reports from others that when Toast downsamples the very high resolution images they don't look as good as when the images are downsampled first by iPhoto.
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 04:40 -
So frustrated can't burn windows movie maker slide show in nero 6
By nijoal in forum Newbie / General discussionsReplies: 3Last Post: 26th Mar 2011, 12:49 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2010, 00:57 -
Photos don't show after burning
By better life in forum ComputerReplies: 3Last Post: 23rd Dec 2009, 20:28 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27
