I purchased the USB Instant DVD product and found one annoying oversite, there is no way to change the bitrate of the SVCD standards in the Ulead Video Studio program. This presented a problem because most people would like to raise or lower the bitrate depending on the quality and disk space desired.
I noticed that the SVCD_par files are not able to be edited and after speaking with Ulead "tough luck". I know the Instant DVD has its own utility that enables you to do this but it works terribly, I end up with sync problems and some of the parameters are not explained at all.
If anyone using Video Studio knows how to change the bitrate of the video being recorded on the fly please let me know.
One more thing, Video studio allows you to edit and change the bitrates after you have recorded the video. This would be great if the video didn't have a sync problem and loss of quality once the operation is completed.
I want to be able to edit the templates or create my own.....remember during the recording phase.
Thanks,
Ernest
<font size=-1>[ This Message was edited by: ejai on 2001-12-17 12:57:16 ]</font>
Results 1 to 1 of 1
templates for Corel VideoStudio X3?
By wingfan in forum EditingReplies: 2Last Post: 25th Feb 2010, 14:10 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 09:35
