Results 1 to 17 of 17
    Jun 2005
    canada
    I have several Pal dvd's which I would like to make copies but as Ntsc.
    How do I get the vob dvd files into SVCD2DVD] so I can convert them to Ntsc?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    use vob2mpg from svcd2dvd.com. Point it at your VIDEO_TS folder on your HD and it will create mpegs from your VOBs. Then use SVCD2DVD as normal on those mpegs.
    Jun 2005
    canada
    I downloaded the svcd2dvdmpg file and when I tried to install I get the message that the Program is Already installed. When I go to Add\Remove I don't see the program listed. I do have svcd2dvd and svcd2dvd v2 listed.
    Is there some other name it's listed as?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    what are you trying to install? VOB2MPG?
    Jun 2005
    canada
    The file was svcd2dvdmpg. Is there a file VOB2MPG? If I missed it I'll look again.
    Jun 2005
    canada
    Found the VOB2MPG. Thanks I'm excited to try it.
    Jun 2005
    canada
    Wow I'm really impressed. If you knew the different programs and processes I've tried and none of which worked. Your's was simple and fast.
    I did get two errors:
    1- An unhandled exception has occurred in your application. If you click Continue.... "79068" is not a valid value for 'value'. 'value' should be between 'minimum' and 'maximum''.
    2- Same but '103044' is not a valid value.
    What is the tab Fix PTS? Am I to run this if I get the errors?
    Even with the errors, I went on to create the Ntsc dvd and it worked fine.
    Thanks Again
    Jun 2005
    canada
    Just another item:
    If I move the Fixed mpg files into SVCD2DVD Assets and run Quick DVD I get the following error:
    Type: System.NullReferenceException
    Source: SVCD2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xece14591aa1abb99.get_x92db45532 f358524()
    at x3284ccece41ee22b.xece14591aa1abb99.get_x925ed0ea7 71f7bd5()
    at x3284ccece41ee22b.x210ff09a2516b1a7.x21f497a09c280 fd5()
    at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xa167076587a68 80d()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    That is something to do with cacluating the audio overhead. What does it say for durtation and audio in the asset window?
    Jun 2005
    canada
    During the Author, the log says Leaving audio source alone.
  11. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What do you get for the following:
    Jun 2005
    canada
    Ok, you'll have to explain how I get the screen.
    Ran Demultiplex & resample audio with the following result:
    VTS_02.MPG, 1.34GB, mpeg2video 720x576 PAL, ac3 48KHz 192Kbps,
  13. That screen (information) is part of the assets display at the bottom of the SVCD2DVD window.
    Jun 2005
    canada
    I'll have to get the info later as I'm currently converting another dvd. I'll get back to you.
    Jun 2005
    canada
    The one I just completed reads the same as the statement above:
    1.43GB, mpeg2video 720x576 PAL, ac3 48KHz 192Kbbps
  16. What is the duration (how long is the play time) of the file?
    Jun 2005
    canada
    Total play time off the dvd is 155 min. There are 3 segments 2653mb each
