I bought my Canon ZR10 camcorder 8 months ago and recorded a lot of my son's school activities. The problem is I could not figure out a way to transfer the miniDV type to VCD. I'm keep buying miniDV types in hope one day I will find a way to burn them to CD
I have a PIII computer with a IEEE 1394 card. I'm going to install windows XP today (can XP help?). What else do I need to do the job without cost too much?
Thanks for any help!
Wei
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
...what OS do you have installed? Since you already have the firewire card, you'll just need the firewire cable to connect the ZR10 to your PC (assuming you've got drivers installed). Also, you'll need a capture/edit software.
You'll transfer the your video thru the firewire, in DV-AVI format. From there, you'll need an encoder (TMPGENC) to convert this AVI to MPEG1.
You forgot to mention a CD Burner (if you already have one). If so, you 'should' have a burning software. If it's NERO, you just pick 'VideoCD' in the start-up menu..and so on.
hope this helps. -
Thanks a lot for your reply!
The OS is windows ME. I'm going to install XP tonight. Once I connect my ZR10 to PC, how do I "copy" the data to PC? I guess what I'm missing is a capture software to do the "copy"? Is there any capture software comes with Windows XP so that I can use without buy another one?
I don't have an encoder. Is it a hardware or a software? Yes, I do have a CD burner with Easy CD-Creator software installed.
Thanks,
Wei -
WindowsXP comes with Movie Maker. Haven't used it yet, so I cannot say how it performs. I've been using the capture/edit software that came with my firewire card. You can also 'buy' this type of software (Ulead VideoStudio, MGI Videowave, Pinnacle Studio 7, etc). Check the 'TOOLS' section, for some downloadable demos.
I don't have an encoder. Is it a hardware or a software? ================================================== =========
You can also get TMPGENC (software) in the TOOLS section on the left side of this page. It's free.
I'm thinking you have the 'lite' version of EasyCD, if it came with your burner. It doesn't have the capability to burn VideoCDs. You'll need the deluxe version (or is it platinum) of EasyCD, or you can 'try' Nero first (full function demo available in TOOLS).
Good luck. -
I think Movie maker only does WMV.
WMV is crap n u want to avoid it.
It can't be coverted to MPEG
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Windows Movie Maker supports DV-AVI @ 25 Mbps which can be converted to MPEG rather nicely. -
For a freeware VCD burner option, you can try VCDEasy and CDRDAO. It'll let you organise your VCD encoded MPEGs and burn it for you too...
/\/\ars /\/\ayhem
Convert miniDV to h.264 using XMedia Recode. Fast moves are very ugly...
By marqus in forum Video ConversionReplies: 3Last Post: 15th May 2011, 04:53 -
Convert from MiniDV to PC
By Tigerjon in forum Video ConversionReplies: 22Last Post: 12th Apr 2011, 21:44 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
Service to convert DVD to miniDV?
By adrien23 in forum Video ConversionReplies: 3Last Post: 25th Oct 2010, 17:53 -
Easy way to convert MiniDV to DVD?
By darkcyber in forum CapturingReplies: 5Last Post: 10th Mar 2010, 14:46
