hello everyone,
i was just wondering wat burning app has it all from CD to DVD image burning. reason is i have a multiple source of images all in different formats: IMG, ISO, CCD, BIN, and MDF. i try NERO and A120% and i get coasters. i cant even find CD IMG, ISO or CCD burners (except CloneCD for CCDs, but i dont like it), and to burn BINs, i use Fireburner, but i need to have a CUE file. so im basically asking wat is a good burner that will give me good burns and lessen the amount of coasters...dramatically. also wat app can mae CUE files? thanks![]()
Wow! You got shocks, pegs... LUCKY!
DVDDecrypter can burn most CD and DVD images, and I prefer it to burn DVD images.
For bin/cue images I prefer CDRWin.
Nero is able to burn most of the images as well.
Almost any burning app can burn all the images.
Exception is CloneCD's format, as most of the programs don't recognize .CCD images, specially that CloneCD creates extra file with 'scratches and errors' data (for use with CloneCD only).
There is easy workaround it, though the image have to be 'clean' (no errors etc). Just rename .CCD to .BIN, and open .CUE file created by CloneCD and change the extension there as well (from .CCD to .BIN) and voila - you can burn it with any other burning app recognising the bin/cue format. -
You can also use ISO Buster to extract the contents of most image files and burn it with whatever app you have. Most of the time, I rename .img files to .iso and they burn without issue.
ok that sounds good, i totally forgot about CDRWin, yeah see i use Isobuster to extract, but i only get a bin, i still need a cue. i guess thats where Cueator comes in. i agree, DVD image burning works very well with DVDDecrypter. i just found out that NERO doesnt burn MDF format, so im having trouble with that. if i were to use Isobuster to extract the MDF contents, or any other image contents for that matter, to BIN and create a CUE, would i be able to burn them fine with CDRWin? thanks
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 03:07 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 04:58 -
Best Image Quality burning AVI to DVD..
By UncleRuss in forum MacReplies: 9Last Post: 29th Jul 2009, 05:06 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
