I'd like to create my own DVDs using my drive LG 4163b but I can't capture in mpeg2.
Power Vcr II 3.0 shows this error:
Microsoft Visual C++ Runtime error - Abnormal program termination
It worked without any error in mpeg1. I know the problem isn't in Power VCR because I have the same error when I encode a file AVI to mpeg2 using Mainconcept Mpeg encoder or TmpgEnc Plus.
I think I need reinstall the mpeg2 video codec but I don't know how to do it. Can someone help me?
My system is: Athlon XP 1700, 384 Mb, 80 Gb hdd, PlayTV Hd video capture card, Win XP pro.
If your card does not come with a hardware mpeg encoder, you need to uninstall Intervideo WinDVD or any other mpeg codec you find by going to Start/Settings/Install/Uninstall programs. Reboot, install Intervideo WinDVD or get the Nvidia mpeg encoder/decoder.
If your card indeed comes with a hardware encoder, uninstall the drivers and reinstall them.
Give it a try.
Buena suerte.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
End of the problem.
I seek and found a mpeg-2 video codec installer at:
http://dvd.box.sk/index.php?pid=sof...&pol=4&rid=7717
After installed it solved the error.
divx to mpeg2 with winff = error
By tors10 in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 14:58 -
Capturing - to what format, DV or MPEG2.?
By Airjrdn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th May 2008, 06:45 -
error message when capturing from Hi 8 Camcorder to PC via the capture devi
By mcreigh in forum Capturing and VCRReplies: 3Last Post: 29th Oct 2007, 16:51 -
Software Recommendations for Capturing MPEG2
By scienceguy_4 in forum Capturing and VCRReplies: 7Last Post: 4th Oct 2007, 19:59 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
