  1. Member Namrepus221's Avatar
    Aug 2002
    Pittsburgh PA
    I tried converting a capped video that I did with the new Divx 6.
    And it said that it wasn't compatable with TMPGEnc.
    Anyone else have this problem?
    It's not the fall that hurts it's the sudden stop
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What was the error TMPGEnc gave you ?
    "Cannot open, or unsupported" ?
    If in doubt, Google it.
  3. Member Namrepus221's Avatar
    Aug 2002
    Pittsburgh PA
    Yeah that's the error
    It says "C:\CAPTURE.AVI can not open, or unsupported"
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Go to option > Environmental Settings, then to the VFAPI plug-in tab. Right-click on the DirectShow Multimedia File Reader, and go to Raise Priority. Repeat this until it is right up the very top.
    Now try loading your file.
    This is also covered at https://www.videohelp.com/tmpgenc.htm#problems .
