  1. HELP!!!!
    I accidently installed DirectVobSub (vsfilter) and now I'm trying to completely remove it from my system.
    Whenever I try to do that, either by "regsvr32 -u" or by uninstalling vobsub completely using uninstall.exe I end up with DirectShow broken and I am completely unable to play ANY video file.
    Anyone knows a solution?
  2. In the end I found the solution myself.
    To completely get rid of dvobsub, it must be unregsvr'ed by every user on the system.
    Mar 2007
    Romania
    Start --> Run, and type: regsvr32 /u vsfilter.dll
  4. DirectVobSub, is the is loaded upon execution of the VSFilter.dll. It can be installed and then run in your PC
    through various video programs/applications (e.g. Avi2Dvd). To remove it, you have to either uninstall the video application
    or do the following:
    - locate (e.g. by search) the VSFilter.dll
    - rename it to e.g. "_VSFilter.bye". If you can't rename it reboot in safe mode and do it.
    this will work for you!!
